APDL 8.3 Released, now only $99/year
Learn more
Results 1 to 5 of 5
Thread: Import Issue: Can't Set Destination Field
  1. #1
    Join Date
    May 2018
    Posts
    2
    I am importing from LogTen Pro. The process has gone fine except that I can't select a destination column for the last few import columns. I have re-sized some of the existing columns in order to give more room at the far end, but even when the horizontal scroll bar is at the right stop the last selection I can make is for the "Dual Received" column. Hopefully a picture is worth a thousand words....
    Attached Images Attached Images
  2. #2
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,378
    Try to size down any wide columns by clicking/dragging the divider between column headings. Alternatively try tabbing across columns, i.e. click a checkbox and map the column then press tab and see if it advances right.
  3. #3
    Join Date
    May 2018
    Posts
    2
    Quote Originally Posted by Neal Culiner View Post
    If you look closely at the screenshot there doesn’t appear to be a column divider after Dual Received (import selection). Therefore even when I resize existing columns I still can’t map anything beyond that point.
  4. #4
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,378
    XC does seem to be the last. It's reading the columns in your supplied import file. TAB delimited is preferred. If you need further assistance send us the file you're trying to import via the help desk.
  5. #5
    Join Date
    Jan 2003
    DTW
    Posts
    805
    resolved via helpdesk ticket.
    Eric Addis
    (A320, A321, B727, B737, E170, SF34)
    Senior Support Engineer
Similar Threads
  1. Import Issue
    By Caseyvigil in forum APDL Sales & Support
    Last Post: 01-28-2017, 11:32 AM
  2. Import issue
    By whiskeypilot in forum APDL Sales & Support
    Last Post: 09-19-2016, 2:56 PM
  3. How do I.... Destination Report
    By theKAT in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 07-04-2007, 3:51 PM
  4. Import field: Ident
    By Robert in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 12-27-2006, 3:03 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
sitemap Site Map
