APDL 8.3 Released, now only $99/year
Learn more
Results 1 to 3 of 3
Thread: Creating TPIC column
  1. #1
    Join Date
    Aug 2018
    Posts
    1
    Is there a way to make a turbine pic column and have it populate automatically? Ideally I'd like it to go to the right of the PIC column.
  2. #2
    diedrichg is offline APDL Beta Team
    Republic Airlines
    Join Date
    Sep 2008
    Posts
    1,427
    I'm not in front of my computer, but here is how to do that off the top of my head.
    Go to Options. Custom Time. Create a new custom Time field - give it a name.
    Still in the Options area, go to Autofill editor and select your aircraft from the dropdown box. Check the new custom time field.
    Still in Options, go to the logbook layout tab and check the box under Custom Time to add it to your logbook view. While here, uncheck any fields you do not wish to see in your logbook layout ("Expenses", for example).
    Go back to the logbook spreadsheet layout. Find the new time column - click and hold the column header and drag it to the position you wish to see it in.
  3. #3
    Join Date
    Jan 2003
    DTW
    Posts
    802
    You are welcome to create a custom turbine PIC time column. However, I personally do not recommend it as the analyzer already tracks this and can show you the TPIC total through the use of filters.
    To find your TPIC total in the analyzer do the following:
    Select..View..Analyzer
    Select ALL DATA
    Click on the Blue Power Characteristics Filter
    Uncheck the non turbine options listed
    Click Back into the analyze grid and the totals will update
    Duration is now total turbine and PIC is now showing TPIC
    If you do want a custom TPIC column in the logbook do the following
    Go to View..Options..Custom
    Click on the Time Fields Tab
    Type TPIC into the first empty field
    Click Close
    Now go to view..options..autofill
    Select The type of aircraft in question
    Place a checkmark in the TPIC box and PIC box. Everytime you enter a flight in that type the duration value will be copied over to the PIC and TPIC column
    Please review the following article on over logging before creating custom columns to avoid over logging
    http://www.nc-software.com/logbookpro/newsletters/2007/05/#over-logging
    Eric Addis
    (A320, A321, B727, B737, E170, SF34)
    Senior Support Engineer
Similar Threads
  1. Creating my own Queries??
    By jareda17 in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 06-07-2007, 12:46 PM
  2. Creating my own trips
    By Beechnut in forum APDL Sales & Support
    Last Post: 11-01-2005, 11:21 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
sitemap Site Map
