APDL 8.3 Released, now only $99/year
Learn more
Results 1 to 6 of 6
Thread: Add/resizing columns in Jeppesen report
  1. #1
    Join Date
    Jan 2013
    Posts
    7
    I've searched but I can't seem to find the answer.
    I'm fond of the Jeppesen style logbook layout and would like to add columns to display other times, i.e., night vision goggle time, aircraft commander, etc, but I don't want to remove any of the default columns.
    I could delete something from the aircraft category/class, but NVG time doesn't really belong under that header, and I can't resize the header either.
    How do I add columns? I would like to size down the width of the columns as it is excessive for some fields (i.e., number of instrument approaches), which would give me space to create a new column(s).
    Thanks.
  2. #2
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,378
  3. #3
    Join Date
    Jan 2013
    Posts
    7
    Quote Originally Posted by Neal Culiner View Post
    I read that article when i was searching and it doesn’t really say anything other than the Jeppesen report is available.
    The Logbook Pro Standard Flight log is editable but it basically just recreates the spreadsheet. I don’t like that look.
    Is there a way to manipulate the column width and also to add columns in the Jeppesen format? Right now all I can figure out is how to change the header title.
    From what I can tell the program allows you to change the width of the individual rows for each logged flight, just not the width of the columns.
  4. #4
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,378
    From the doc page referenced above:
    The report designer takes a typical Jeppesen style layout and allows you to modify it to fit your needs. Click on a desired column then set the items in the far left side of the designer. Items such as the column header caption, data field, data alignment, font settings and the row height of the final output can be set. Click the option to save the template, any name as you desire, and add new templates to meet your needs. After a template is created it will automatically appear in the Reports..menu just below where the custom template menu item appeared. With the custom template system, you can create your own content and modify formatting within the parameters of the left side preferences. Columns cannot be removed, hidden, resized, or reordered.
  5. #5
    Join Date
    Jan 2013
    Posts
    7
    Ah, bummer. Is there any way to possibly add that capability in? I’ve got a pretty diverse logbook and I’d like to have it displayed in a Jeppesen style.
  6. #6
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,378
    Quote Originally Posted by insanebikerboy View Post
    Not in the near future.
Similar Threads
  1. [General] Jeppesen format report
    By nightrider in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 07-01-2016, 2:48 PM
  2. Change/Add/Delete Report Columns
    By Bill'sBuddy in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 11-07-2006, 8:03 PM
  3. Jeppesen Style Report Date Field
    By caughron in forum Logbook Pro Desktop Edition Suggestions
    Last Post: 03-05-2005, 5:03 PM
  4. Combining two data columns in a report.
    By Brandon in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 06-01-2004, 12:25 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
sitemap Site Map
