APDL 8.3 Released, now only $99/year
Learn more
Results 1 to 7 of 7
Thread: Trouble exporting trips from APDL.net. Dates selection
  1. #1
    Join Date
    Jul 2014
    Posts
    4
    Hey Guys
    So something weird is going on with APDL.net when it comes time to export data in a certain date range. So here is what I tried to do today.
    For example, I would select 11/29 through 11/30, but I only would get 11/30 flights, not 11/29 flights
    But when I select 11/28 through 11/30,
    I would then get one of my flights from 11/28 (I did four legs this day), then both of my 11/29 legs and I would all of my 11/30 legs. What's going on here that I am not understanding. In UTC time, if I select 11/29 and 11/30, shouldn't I get all of my legs that occurred starting from 00:00 on 11/29 through 23:59 on 11/30? What is the system logic? I didn't have this problem earlier this month.
  2. #2
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,418
    What are your OUT/OFF times, not DUTY?
  3. #3
    Join Date
    Jul 2014
    Posts
    4
    Even the out and off times are still in the time frame.
  4. #4
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,418
    Review the payroll settings for these legs in the app and make sure Apply to Flight is ON.
  5. #5
    Join Date
    Jul 2014
    Posts
    4
    Apply to Flight is on for these legs..... This issue starting happening recently...
  6. #6
    Join Date
    Nov 2001
    Richmond, VA
    Posts
    12,418
    I took a look at your data and did a custom export for the dates you mentioned and I get the following returned. If this is missing something please provide screenshots of the LEGS from APDL.
    Attached Images Attached Images
  7. #7
    Join Date
    Jul 2014
    Posts
    4
    Quote Originally Posted by swakid8 View Post
    Unforunately, same results for me
Similar Threads
  1. APDL.NET - Template for Manually Building Trips
    By I5xswipe in forum APDL Suggestions
    Last Post: 07-28-2017, 10:15 PM
  2. Question about exporting Duty Length from APDL.net
    By diedrichg in forum Logbook Pro Desktop Edition Sales & Support
    Last Post: 01-16-2017, 5:54 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
sitemap Site Map
