Frontier Airlines help
Sorry, they use the FAR definition, so when the plane moves under it's own power with intent to fly until brakes set. It starts somewhere between out and off and ends at in. I just started here and our instructor was adamant about the flight time. Thanks
This has been covered and remedied. Enable Taxi Time under Settings-General-Misc
“If you would like to use FAR 1.1 to calculate your legality, you can turn on "Enable Taxi Time" to display an additional field on Leg View which will allow you to enter the time the aircraft first taxied under its own power to differentiate from block out time which is at pushback.”
