Schedule Import, Delete Leg
JustinB
Good morning,
Here is a schedule that I just imported. I am using the latest versions of all the software.
D3A11A : 01OCT ONLY ON SUN BSE REPT: 1200L Operates: Oct 1 Only
Base/Equip: DEN/319 FO01
DY DH C FLTNO DPS-ARS DEPL ARRL BLKT GRNT TBLK TDHD TCRD TPAY TDUTY LAYOVER
SU NTR DEN-DEN 1355 1356 0000 0059
SU 575 DEN-SLC 1455 1615 0120 0040
SU 129 SLC-DEN 1655 1815 0120 0240 0240 0630
D-END: 1830L T.A.F.B.: 0630
Total: 0240 0000 0000 0240 0630
In APDL on the PPC, you see the three lines, NTR, Flight 575, and 129, the times are correct on each line. I choose to delete the first leg, NTR. Now the two legs that are left are 575 and 129, however, both of the scheduled times are the same, 1655 departure and 1815 arrival. The times 1455 and 1615 are lost for flight 575.
Can anyone else duplicate this? My PPC time is set to local when I import, I switch it to zulu after the import.
Justin
I checked out the schedule importer and as long as I used the Generic Crewtrac filter at the top of the list, I had no problems with importing the data. If you are having problems at that point, make sure you have the latest schedule importer version 6.1.5.
If the import is fine and the problem is actually with the software on the Pocket PC, let us know and we can investigate further.
Thx,
PPC problem then...
Thanks for looking into it. I was using the Frontier filter, it imports correctly, but I delete the leg in APDL on my PPC. So, I will post over into the APDL support.
Thanks!
Justin
