Show Time..
Redbaron64
APDL Beta Team
Arizona
Morning..
flights running late (WX), and show time was changed to 20:00 local.. can I show the new Duty / FDP (20:00) without changing other parameters?
You have to change the scheduled departure time because APDL will not let you have a report time after scheduled departure time (that would be impossible). You also have to make scheduled arrival time after scheduled departure time, because that also cannot be before scheduled departure time.
So change the scheduled times first, then you can change the report time.
ok.. could the actual times override the same idea? probably FAR based on scheduled not actual, most likely.. yes?
Report time after scheduled departure time is not at all impossible, it happens all the time. Scheduled time is per the definition what is scheduled and that will not change even if the departure and arrival times are delayed. It would be really helpful is it was possible to keep the scheduled times in the log, while being able to update the duty time for 117 calculations.
FDP limits are determined by scheduled reporting time, not merely actual reporting time, unless the assignment is modified before you enter rest. Generally speaking crew services changing your showtime after you in rest doesn't change FDP calcs. 117 rest is prospective
