Trips would not import
Meech
Neil or Paul,
These trips would not import either onthe web based importer or the one installed on my computer. Here is a copy of them
John
Jul **
02 -- 05 06 07 -- 09 -- 16 17 -- 19 20 -- 23 24 -- 26 -- 30 31 **
SA -- TU WE TH -- SA -- SA SU -- TU WE -- SA SU -- TU -- SA SU **
8909 2250 0 238 2528 6 75
841 1 757 DTW-DCA 230 1355 1519 124 55 1255
841 1 757 DCA-DTW* 347 1614 1752 138 124
841 1 757 DTW-LAX 331 1916 2105 449 751 751 1125 1645 1815 2120
---------------------------------------------------------------------------> See Detail #1 <-----------------
841 2 753 LAX-HNL D 91 1520 1750 530 530 530 700 2635 2805 1405 1805&nbs
Neil or Paul,
I forgot to include that they are trips for Northwest and I did select "Northwest"option on the importer program.
John
John,
Did you view the sample NorthWest trip format in the documentation? Please see the PDF documentation for the Schedule Importer and see the required format for NorthWest the schedule importer uses.
We are also looking into your support ticket and we'll reply shortly.
Below is the format for the NorthWest filter, per the sample in the SI documentation:
Northwest
Filter Input Format:
3802 1 320 MSP-FLL*E 1906 711 1138 327 132 611
3802 1 319 FLL-DTW*U 243 1310 1607 257 120
3802 1 320 DTW-BDL A 276 1727 1900 133 757 757 1204 957 1112 1915
------------------------------------------------------------------------- ANY HOTEL XXX-XXX-XXXX
3802 2 319 BDL-DTW A B 1183 612 815 203 109 512
3802 2 319 DTW-DFW E 1183 924 1114 250 453 453 717 2726 2841 1129
3802 3 319 DFW-DTW*G 696 1555 1930 235 127 1455
3802 3 319 DTW-PBI A 892 2057 2336 239 514 514 756 1439 1524 2351
3802 4 319 PBI-DTW X DH 891 1500 1748 248 128 1430
3802 4 320 DTW-DEN G 1225 1916 2021 305 305 553 806 1024 1139 2036
------------------------------------------------------------------------- CREW HOTEL XXX-XXX-XXXX
3802 5 320 DEN-DTW H 1224 800 1243 243 57 700
3802 5 320 DTW-ATL*A L 1224 1340 1534 154 155
3802 5 320 ATL-MSP G 1433 1729 1919 250 727 727 1134 0 0 1934
Detail #1 : Other Hotel Info
Looks like I cannot include any info above the 1st leg of the trip. I retried using just the info below the date line starting with the 1st leg and it worked. Problem solved, Thanks.
John
One trip wont load properly
Neal or Paul:
I am with united using the scheduler importer on our November posted schedule. ID33 imported just fine. But ID24 would not list any days except day 1, and had all wrong info for that date.
EFF 10/31/05 THRU 11/30/05 ID 0024
77I 241 ORD DEN 0800 0935 .50 B 2.35 2.35
77C 902 DEN IAD 1025 1535 16.52 L 3.10 5.45 7.50 .00
HILTON WASHINGTON DULLES 703-478-2900
77C 479 IAD DEN 0827 1029 2.06 B 4.02 4.02
77C 402 DEN IAD 1235 1749 23.41 L 3.14 7.16 10.37 .00
WASHINGTON HILTON&TOWERS 202-483-3000
77C 903 IAD DEN 1730 1925 13.40 3.55 3.55 5.10 .00
DEN MARRIOTT GATEWAY PK 303-371-4333
77C 944 DEN ORD 0905 1235 2.30 2.30 3.45 .00
T/D- 4 BID-20.00* FTM-19.26* TMA- 77.50 INT- .00 NTE- .00 M$-143.99 T/C- .34 7.43* this is what I am trying to import
trip wont import properly
Neal and Paul. To continue, after copying the above trip to the importer and trying to import, this is all that the importer came up with to import.
It had one leg only, with the total trip time and time away, and nothing else. could not edit the imput because it would only edit one day of the trip. and ID 33 of the same month loaded perfectly. Any ideas..
