Deleting
Radial Song
I have accidentally imported the same file twice and have double entries. How do I delete the entire section so I can redo the import?
If you want to clear your entire log area data and reimport, then you would use the REPLACE option on the Import Wizard. Be sure you create a backup before any import attempts so you can revert/restore to the prior checkpoint. Speaking of which, if you did not disable the backup option, it should have created a backup prior to importing, you can click File..Archive..Restore to restore back to the prior log data date and time.
If you need additional help, let me know.
