import additional columns
mattm
I've imported my logbook data from an older program via a tab delimited spreadsheet. After the import I needed to do a little bit of cleanup work to get things right.
Unfortunately, I forgot a couple of columns during the import. I really don't want to import from scratch - is there a way to only import the missing columns into Logbook Pro without losing the work I've already done?
Matt,
I am sorry but you will have to reimport or make the changes manually. Just restore to the backup file you created prior to the import then reimport the the flights. If you want you can save your import layout prior to importing. This would allow you to quickly map the fields in case you have to reimport again.
