Multiple Trips on Same Day
HvyJet
Neal
When importing from APDL multiple trips on the same day only the first trip will import...I then have to manually input the legs from the next trip on that day....is this a limitation?
Barney
Hello Barney,
You should be using Logbook Pro 1.10.23 and APDL 6.x. In the PDA Wizard you should have "By LogPage" selected. Until 1.10.24 comes out (scheduled for later today) clear the checkbox next to "APDL Reports" as we have a bug in there. You should see the log page combined into one entry in Logbook Pro. If not, tell me more details such as which PDA you are using (Palm OS or Pocket PC), if Pocket PC it is recommended you go to Options...Exit prior to importing into Logbook Pro.
Neal
Ver1.10.23 and 6.0.2 APDL
checked"by logpage" using Palm OS and now when you import the day it still imports only the first trip and NO out and In times...
Barney
ok
but, it still imports only the first trip of the day...the second trip does not import...see original post and replys....so why does it not import all trips on a single day? right now it imports the first trip i have to manually input the following trip information....
barney
Neal
I dont see anything unusual about the trip. I have always had to enter the second trip of the day into LBP manually. These are the 2 trips in the "recap" ....Flight 1408/08 will not import after 1290/08.
Barney
Trip Recap
Trip 433 MEM 30 07JUL06
Shows in 0 days 0:00 hours
Block 733 Pay 7:33
R D Flight ------ Scheduled ------- -------- Actual --------
R Flight H Date Org-Dst Eq Dprt Arrv Blok Turn Duty Dprt Arrv Blok Turn Duty
SHPM15 07Jul06 MEM-MEM 0739 0740 1 114 0739 0740 1 128
1490 07Jul06 MEM-RNO 30 0854 1250 356 1235 541 0908 1306 358 1219 557
1290 08Jul06 RNO-MEM 30 0125 0502 337 507 0125 0515 350 520
---- T O T A L S C H E D U L E D --- ------ T O T A L A C T U A L -------
Away Blok DH Dty Min Trip Totl Pay Away Blok DH Dty Min Trip Totl Pay
2153 733 733 2206 748 748
D Employee L B
Pos Asg V Number Pilot Name C R
Trip 9 MEM 30 08JUL06
Block 745 Pay 17:40
SHPM15 08Jul06 MEM-MEM 0745 0746 1 114 0745 0746 1 104
1408 08Jul06 MEM-ABQ 30 0900 1121 221 5934 406 0850 1117 227 5938 402
2351 10Jul06 ABQ-LGB 30 2255 0046 151 136 2250 0044 154 141
2351 11Jul06 LGB-MEM 30 0222 0555 333 830 0225 0608 343 843
7040 745 1740 7053 804 1743
D Employee L B
You can use the "Add Trip Today" function under the edit menu on the PDA to create a second logpage for the days when you have you two FAR duty periods that start on the same day.
Is this the only solution? I'd like to avoid manually entering trip information; that's why I use APDL Schedule Importer...
Possible workaround, don't know if would be too much work or not.
Import one trip and go to your pda, copy logpage, paste it on another day. go back to schedule importer and import your other trip, go back to pda, find the first trip you imported, copy, go back to the actual day of trip and paste in the logpage.
I might be missing something, haven't tried it myself. Just a thought.
Thanks, but it is a lot of work for the results. It would be easier for me to just enter the info manually in logbookpro. Guess that's it for APDL for me; doesn't work anymore...
