Reports
Hicks Milner
Atlanta, Ga.
I changed the routing to "From" and added a "To" column to match the Jepps logbook. My problem is that I can not get any reports to print out with the TO column.
Any suggestions?
Thanks, Hicks
Hello Hicks,
You'd have to create a custom report template and change the columns and data fields accordingly. Please review the "Reports" help topics for additional assistance if needed. The main thing is to select the desired column, change the column header/caption, also set the data field, then save the template.
