Setting up Minimum Day(Duty Period) and/or Trip rigs
av8rleo
Currently my airline has a 4.0 hour per duty period which applies to the first moment a trip reports, until it releases such as you see below...
M2095 11/05/14 BSE REPT: 0640 REPORT- 11/05/14 LOCAL Times
We 05 5840 MSP-EWR 0719 1053 0234 4625 0234 0000 0400 0400 0328 EWR 1807
D-END: 1108 ( ) REPORT 0515 Country Inn & Suites Air (908)282-0020
Th 06 5812 EWR-MSP 0553 0800 0307 112 4752
Th 06 5711 MSP-IAH 0912 1150 0238 4752 0545 0000 0624 0624 0750 IAH 1720
D-END: 1205 ( ) REPORT 0525 Marriott Houston North (281)875-4000
Fr 07 * 5725 IAH-MSP 0602 0845 0243 225 4630
Fr 07 5705 MSP-BZN 1110 1236 0226 4625 0509 0000 0527 0527 0826 BZN 1624
D-END: 1251 ( ) REPORT 0515 Holiday Inn Bozeman (406)587-4561
Sa 08 5691 BZN-MSP 0559 0917 0218 106 4630
Sa 08 5785 MSP-IAD 1023 1332 0209 103 4630
Sa 08 5764 IAD-MSP 1435 1600 0225 4630 0652 0000 0735 0735 1000
D-END: 1615 --------------------------------------
TOTALS BLOCK 2020 DHD 0000 CREDIT HRS. 2326 T.A.F.B. 8135
As you can see Wednesday the 5th blocked less than 4 hours, so Minimum Duty period credit of 4:00 applied and kicks in...
We currently also have (at least until it changes) an Average Daily Trip Guarantee (ADTG) of 4.75 per calendar day that kicks in if the 4.75 is not met. See below...
M2115C 11/21/14 BSE REPT: 1640 REPORT- 11/21/14 LOCAL Times
Fr 21 5699 MSP-BZN 1719 1844 0225 4625 0225 0000 0400 0400 0319 BZN 2001
D-END: 1859 ( ) REPORT 1500 406-587-4561
Sa 22 N MIN BZN-BZN 1500 1500 0000 0000 0000 0000 0000 0000 BZN 1415
D-END: 1500 ( ) REPORT 0515 406-587-4561
Su 23 5691 BZN-MSP 0556 0920 0224 4612 0224 0000 0400 0400 0320
D-END: 0935 --------------------------------------
TOTALS BLOCK 0449 DHD 0000 CREDIT HRS. 1415 T.A.F.B. 4055
So as you can see by the raw times, this trip did not meet the threshold of 4.75 per day, so it had to have ADTG added into it in the amount of 6:15.
Essentially it first gained 2 minimum duty period guarantees (4.0 each for 8.0 hours). Then it had to have 6:15 added to it to make it get to the ADTG threshold...
So the question is, how do I set this up in APDL to make it work correctly...
Thanks!
I don't completely understand the ADTG you mentioned. Does that mean your trip always pays a minimum of 4.75 times the number of days in the trip? So a 4 day trip always pays at least 19 hours, 3 day pays 14.25 etc?
Currently, APDL does not have an option for a trip "rig" based on block time rather than TAFB.
You can use "minimum credit" in APDL to accomplish the first part of your situation though. To set up minimum credit in APDL, go to settings/payroll and choose the appropriate payroll category. I suspect that would be "block" and set "minimum credit" to 4+00. This is minimum credit per day that "block" is selected.
I will log the ADTG part for review and implementation in a future update.
Thanks for the insight guys... as it turns out we are now going away from 4.75 ADTG to 4 hours pay AND credit on calendar day layovers. I'll check to make sure I have the minimum credit set up as specified above...
Any suggestions as to why my minimum credit of 4 hours is not showing up for training events? I'm guessing I have something set incorrectly...
As you can see the image on the left shows the detail for the Payroll Category "Training"
I have it set up to apply to Legality and Apply to Pay and have 1:1 leg rig turned on (it originally wasn't but I was changing settings to try to get it to reflect correctly).
The image on the right shows my 8 hours of duty for yesterday, but isn't showing 4 hours or credit.
So what have I done incorrectly?
Thanks!
