APDL -> LogbookPro Remarks
Rico33309
On an old version of singlesync transferred the remarks as the following
Flight Number : xxxx Crew : T Striker Notes : 25. It would be nice to see a similar setup for the additional Notes.
Actually it does not follow the same pattern. Currently it will fill the remarks as follows:
"(notes data) Crew: xxxx Flight: xxxx"
Thus the remarks looks like this
18L Crew: T Stryker Flight: 9200
The format of "Flight : xxxx Crew : xxxxx Notes : (remark data)" is easier to read.
If you can explain how to reorder the population of the fields, I'll be glad to try it out.
There is no way to reorder the pattern. This is the way the PDA Wizard inserts them which is not configurable at this time. I don't anticipate this changing to be honest, hopefully the new pattern is acceptable.
