Closing Program
ibarnett
Robina, Qld, Australia
The data from my last page is not saved when closing using the "close Button",
It IS saved if I use the "exit" from the "options menu".
I recall this happened from the previous version (now using version 6).
Is this on the fix list for the upcoming version?
I assume you are using the Pocket PC edition. If so, it is suggested to click the S to save your data prior to exiting the program. The Pocket PC has various schemes of preserving memory that may or may not close the application depending on how you exit and how much memory is available on the device.
For all Pocket PC applications the "X" at the top of the application actually is a minimize button. The program remains in memory until the Pocket PC runs out of memory and then is asked to close. At this point the software will save any edited data if the (Done) button has pressed.
You will notice this when you tap "X" and then tap the "AirlineLog" icon, the application will reopen to the logpage screen.
As Neal suggested, when in doubt tap "S" to force a save.
Fly Safe!
Paul Auman
APDL Development Team
