Dead Heads, credit times
m4j2t
I'm importing with a generic crew trac filter. The deadheads get entered as block time, and this can mess up rest calculations if I miss it. (I go through and change it manually, but I have missed one or two)
Also, Is there a way (filter) to get the importer to read the CREDIT times off the pairing? right now the payroll summaries are incorrect because our credit times are usually a couple minute different than the block times.
here is an example pairing with a deadhead and different credit/block times.
d1013 ONLY ON WED BSE REPT: 0930L OPERATES- JUN. 14-JUN.
Base/Equipment: DEN/BE1 CA01FO01
WE 5029 DEN-GCK 1030 1238 108 108
WE 5030 GCK-DEN 1300 1312 112 113
WE 5096 AMA-DEN 1830 1903 133 135 202
WE 5171 DEN-GJT 2105 2212 107 108 632 0 638 0 1257 GJT 1813
D-END: 2227L (NR 900) REPT: 1640L LA QUINTA INN (970) 241-2929
TH 5188 GJT-DEN 1740 1846 106 109 44
TH 5159 DEN-GRI 1930 2154 124 130 230 0 239 0 429 GRI 1441
D-END: 2209L (NR 900) REPT: 1250L HOLIDAY INN MIDTOWN (308) 384-1330 SHUTTLE
FR DH 5036 GRI-DEN 1320 1352 132 49 146 BE1
FR 5095 DEN-AMA 1538 1810 132 134 20
FR 5096 AMA-DEN 1830 1903 133 135 305 49 358 1 728
D-END: 1918L --------------------------------------
TOTALS BLOCK 1207 DHD 49 CREDIT 1315 T.A.F.B. 5748
