I use LP with ADPL. is there a way I can have it place multiple aircraft idents in the aircraft box? Also if my first leg is a deadhead it will put unknown in the ident box is there a way to avoid this?
I know what you're asking. When you sync. from APDL you're using a summary, like one line per day, and if your first leg is a deadhead and you don't put an 'N' number in that field you get the "UNKNOWN".
I think that's mostly a feature request for APDL - I don't think LogbookPro has a clue what's going on, it's just inserting what APDL dumped in the upload directory.
I don't think you can get multiple 'N' numbers in the field, the "hack" to fix your problem (since you probably don't care what the 'N' number is of the plane you deadhead on) is to just add the 'N' number of the plane you first fly into the first leg of the day (the deadhead) and it will then copy that 'N' number up to LogbookPro.
Multiple 'N' numbers would be nice though.
