Since the later builds and also in the final build 214 i noticed a rather nonstandard behaviour in using the dropdown listboxes using the spreadsheet style. Since i use almost exclusively the keyboard while entering flights, this is a little bit annoying...
Windows Standard should be using alt/arrow-down to open the list, then up- and down-arrows to select the entry then TAB to jump to the next field.
In logbookPro i have to hit enter before jumping to the next field with the TAB-key. I know, this is not a major issue, but you can solve this with the next release, please?
Otherwise a superb job with the new release!
Kind regards,
Jens
Kind regards,
Jens
