Hi,
You can reaccomplish your import assuming your logbook contains nothing but your imported data by choosing the replace/purge option in the import wizard. This will reaccomplish your import from scratch, in other words, remove all existing 'Logbook' entries prior to importing. Aircraft configuration information will NOT be removed. The import wizard checks to see if the aircraft type exists, if not, it adds it for you, then you have to configure it. Regardless, ALWAYS backup prior to modifying your data to resolve your issue.
