geira
- Joined
- Nov 15, 2001
- Messages
- 18
Hi Neal
I wasn't planning on bothering you with this bug until after the holidays /forums/emoticons/angel.gif , but since you're already hard at work;
On your PPC you go to regional settings and select: 'Norwegian (bokmål) Norway'
When you open the logbook window and press the date window you end up with the following error code: 'Error Code 13 Description: Type mismatch Source: Logbook_Pro'
This error only occurs in the logbook window. Ratings, Certificates And History all work normally, the 'date-select' window pops up like it should.
When I switch regional settings to English everything works fine.
Thanks, Geir
BTW. I can confirm that AppForge Booster works fine on the Fujitsu-Siemens Pocket LOOX 600.
Thanks, Geir
