High DPI display
edwin
Just installed evaluation version, however it appears unusable on my high resolution (1920x1200) display, running at 163 DPI. I assume this problem exists throughout the program, but for example the add new aircraft button is not visible on the aircraft tab, (there appears to be a thin line where it should be, but it is not clickable). Does LBP support high DPI settings ? (this is required for Vista I believe) I am running XP. Any suggestions (other than reconfiguring my display). thanks
Thanks for the relevant response. However I won't go back to a lower DPI, even for an interesting product like LBP. I hope your V2 will support custom DPI.
