How do I get "total day" hours to display on a custom report?
Hi all,
I'm having a little trouble, and I'm hoping someone out there has a creative solution. I've created a custom template that more or less matches the "ASA Standard Pilot Log" (ASA-SP-30), so that I can print it out and try to find errors on my page totals. I customized a Jeppesen style logbook, and rearranged the columns to more closely match the colum order in my ASA logbook (is there any way to reformat the column widths??). However, I wasn't able to figure out how to get the report to create a "DAY" column that would total hours flown during the day (i.e. not at night).
Phil
Hi Phil,
No, I'm sorry, column widths are not adjustable at this time. Logbook Pro does not log DAY time unless you manually created a custom time column to log it separately. Logbook Pro logs 'Duration' and 'Night'. You could export to Excel and have a simple formula that subtracts the two columns, if that would work out. There's no way to add a calculated column in this version, but is something being worked on for version 2.
