ident and route info
blkchrry37
I recently downloaded logbookpro for a trial period. The ident and route I put on the first page in my hp pocket pc transfers to every subsequent page and cannot be edited or changed. I uninstalled on the hp pda and reinstalledbut got the same result. All other blocks seem to accept new info and keep it when saved. I am using windows xp on my pc and the hp pda has windows 2003 for pda. Anyone have any thoughts.
Make sure you are using the latest version and that you are not trying to sync with a clone if using Logbook Pro Professional or higher. You may want to try uninstalling and reinstalling ActiveSync and the PDA software to see if you can get a proper synchronization. It is also likely that you may have missed one of the checked tables when configuring the database import. Please rerun the install routine to ensure you have configuration as described in the help documentation.
