Making changes to data fields...
nigelcobalt
Utah
Is there a way to edit an existing data field? For example, I was checking the accuracy of my logbook (LBP, win xp) and I noticed that in one of my aircraft (piper arrow 200) I forgot to check the box for complex. I want to correct this and make all of those pa200 entries show as complex time. Is there an easy way to do this or do I have to go back and edit each entry manually? Thanks...
Please go into OPTIONS AIRCRAFT and check the complex box for the specified aircraft. When you rerun the analyzer the complex time will be updated.
If you created a complex column in your logbook you will manually need to add the times into in the spreadsheet view.
