I recently imported my flight level data to Logbook pro and all my time is in minutes (183.0) rather than decimal(3.1). How do I convert back to decimal?
When using the Import Wizard you can select the time format on the lower left of the first dialog. Logbook Pro will convert it to decimal for you automatically.
No, you cannot. Once the data is 'in' there are no conversions available. I suggest regressing to your backup prior to import then reaccomplishing the import. Unless you changed the option to backup your data during import, the Import Wizard creates a backup during the process.
