Signature block?
kd2473
Hi, I see from the documentation that I should be able to load a signature block, but I have followed the steps recommended and nothing showed up either on the screen or on the print out. Also, it took forever to generate the report I needed. Any pointers you can give me would be gratefully received!
What is the name of your data file (ends with .LBK)?
What is the name of your image file?
Please follow the specific directions found in this help topic. Also make sure you are using the latest version.
Hi,
I updated to the latest version a few days ago, so that should be fine.
Logbook is PJMenner1.lbk
When I open My Documents they sit right next to each other
The resolution is slightly higher than is advisable (200dpi) but I can't reduce that.
