Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
APDL 15.5 is now available on the Apple App Store. Click here to read the release announcement. Click here to go to the Apple App Store to install now.
I'm looking for a way to get a report sorted by aircraft ident. I'm looking for total hours over a given period of time in each of the individual aircraft in the logbook, by tail number.
I'm thinking (yes, it hurts) but the only way I can think of doing this is to open the Spreadsheet Style log, click the Ident column header, which will force a sort of this column. You can then print directly from the spreadsheet view and this will provide your report, sorted by Ident. You can also select a range of rows and print just those rows if desired.
You can also use the Explorer and click the column headers to sort by which column you desire.
This one is much easier! Open the Analyzer, click the + sign next to the Type on the left side and you'll see the break down by Ident. You can print from the Analyzer if you need the information in hard copy format.
