Sync issues
whiskeypilot
I opened my app today and I keep getting sync failed. Ive been connected to my wifi and then my mobile provider. Both indicate sync failed.
Another issue, I've been trying to import trips from Air Wisconsin and I have to use the computer to do it. If I try to use the app, it shows all my start dates as the current date. loading 4 trips on the same day. I cant figure out how to edit the dates prior to importing the trip. a typical Air Wisconsin paring looks like this and works fine when using the PC.
Pairing P4388
DayDHFltDPS-ARSDepArrBlkSegTurnTailCrew
Show: 0645
SU 26
3787PHL-PIT07300840011001100025N/ASADLER C, SANTILLAN J
SU 26
3787PIT-LGA09051027012201220058N/ASADLER C, SANTILLAN J
SU 26
3961LGA-MVY11251243011801180047N/ASADLER C, SANTILLAN J
SU 26
3961MVY-LGA13301431010101010149N/ASADLER C, SANTILLAN J
SU 26Y4218LGA-YUL16201755000000000000N/A
Rls: 1810 Duty: 1125Rest: 04510626RON: 1150
1-514-697-7110 HOLIDAY INN POINT CLAIRE
Show: 0600
MO 27
CUSYUL-YUL06000601000000150044N/ASANTILLAN J
MO 27
4084YUL-PHL06450819013401340041N/ASADLER C, SANTILLAN J
MO 27
3788PHL-BWI09000947004700470028N/ASADLER C, SANTILLAN J
MO 27
3788BWI-PHL10151102004700470048N/ASADLER C, SANTILLAN J
MO 27
3902PHL-BUF11501303011301130000N/ASADLER C, SANTILLAN J
Rls: 1318 Duty: 0718Rest: 04210436RON: 1557
1-716-8107829 STAYBRIDGE STES AIRPORT
Show: 0515
TU 28
3996BUF-BOS06000723012301230027N/ASADLER C, SANTILLAN J
TU 28
3824BOS-BUF07500924013401340025N/ASADLER C, SANTILLAN J
TU 28Y3873BUF-BOS09491110000000000000N/AJACKSON N, NESBITT K, RIDENOUR R
Rls: 1125 Duty: 0610Rest: 02570418RON: 1925
1-781-485-3600 COMFORT INN AND SUITES LO
Show: 0650
WE 29
TAXBOS-BOS06500700000000100050N/ASANTILLAN J
WE 29
WE 29
3873BUF-BOS09491110012101210030N/ASADLER C, SANTILLAN J
WE 29
3962BOS-PIT11401326014601460224N/ASADLER C, SANTILLAN J
WE 29
4015PIT-PHL15501705011501150000N/ASADLER C, SANTILLAN J
Rls: 1720 Duty: 1030Rest: 05560606RON: 0000
TAFB: 8235 18052126
Are you able to login to http://nc-software.com/MyAccount - if you can't sync it could be an account issue. Contact support for assistance with that if needed further. For schedule importer issue, as your trip data does not have a date it is set to today's date. You should use ONLY the APDL.net schedule importer and set your trip start date and then you can import to the app.
I have no issues logging into either site. My subscription shows it expires 1 year from today which I don't think is correct. I have no option to buy more subscriptions. It says NA.
The way Air Wisconsin does it, you log into your current months schedule then press print. I copied that and pasted it. The trip is displayed with days of the month, not month and then day.
Aric,
I deleted your screenshot above so others don't see it, ironically I should have looked at it closer because from what I see your APDL subscription is expired per http://nc-software.com/MySubscriptions - I'll see why you are not showing that in the app. You can renew at APDL - Airline Pilot Logbook App for FAR 117
As to the schedule importer issue you'll have to import on APDL.net only. We have a case in the tracker to handle this app side like we did in the Palm version when the processor can't pickup a date so it has to choose something so it sets today. Not ideal, the moral is you have to do this online only.
Aric,
Okay, I updated it using the website and my sync function came back. Thanks. It usually prompts me in the app and I update through the App Store. I've never seen the NA next to purchase. Thanks for looking into it.
