• APDL and Logbook Pro for Android are now in public beta. Click here to join the public beta and install the latest versions today.
Air Canada Schedule Import
Bond13
Hi I'm trying to import a schedule just assigned to me that I am copying from the company’s "WebCruise" site. After I copy and paste the information and select "Import Pairing" I get the warning message: Check the trip format, unable to find all data. I have tried all 4 selections for "Airline Filter"
Hre is the pairing:
DISPLAY PAIRING KMSQ
CM2611C
SEQUENCE NO: T1111 DATE: 26APR06 SEATS: FO OPTION:
T1111 APR 26 WE (AS SCHEDULE ) EFF. APR 26 - APR 27 ONLY WE
1044 YYZ 0905 DFW 1120 1 3.15 .00 3.15 LDS BW
HAR BLK 3.15 .00 3.15 PLUS 000 ON-DTY 4.45 L-O 17.40 DHD .00 DPG 1.10
1045 DFW 0630 YYZ 1034 1 2.34 .30 3.04 B CBBW
708 YYZ 1115 LGA 1240 1 1.25 .00 1.25 L 1115 1240
713 LGA 1330 YYZ 1504 AC 1 .23 .24 .47 1330 1504
BLK 4.22 .54 5.16 PLUS 000 ON-DTY 9.04 DHD .47 .00
TRIP TOT 7.37 .54 8.31 PLUS 000 TOTAL 31.29 NO-DYS 02 DHD .47 DPG 1.10
CREDIT-TIME 9.41 ($ .00)
FO BOND (N/H-TRNG) 11111
WILLIAM RS
XXXXXX 11111
XXXX FD
HS REMARKS: MAGSKZ/MAHAIM
I'm using APDL 6.0.1 build 102605 and APDL Schedule Importer 6.1.2 Thanks in advance.
Francos_Duf
Trenton, Ontario, Canada
[FONT=&quot]As of last week, there is a new Air Canada import filter based on the ReportLink data which solves all issues and even allows for crewname import (which you can edit also prior to finaliizing the import)
[/FONT]
[FONT=&quot]Here is a step by step guide to reportlink imports:[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]1-[/FONT][FONT=&quot]Log in to Report Link[/FONT]
[FONT=&quot]2-[/FONT][FONT=&quot]Selective “active calendar” option for the month you want to import from[/FONT]
[FONT=&quot]3-[/FONT][FONT=&quot]Left click on the pairing Icon at the start of the first pairing you want to import. A new tab or window should appear with only the pairing info.[/FONT]
[FONT=&quot]4-[/FONT][FONT=&quot]Left click on the “Printer Friendly Version” in the top right corner of the window (Not on “Print this page” which is on the left hand side). This should bring up a new tab/window with an embedded PDF document.[/FONT]
[FONT=&quot]5-[/FONT][FONT=&quot]Left click at the start of the date (Top left) and hold. Then drag the mouse to the bottom right of the window stopping at the end of second pilot’s Rank which in most cases should be FO.[/FONT]
[FONT=&quot]6-[/FONT][FONT=&quot]Right click on the highlighted section and select “Copy”.[/FONT]
[FONT=&quot]7-[/FONT][FONT=&quot]Go the APDL online importer and select paste in the trip info section. You can either select “auto” recommended or select “Air Canada (ReportLink) Updated: 02/14/2010” then press “Import”. You should then get the “1 Trip added (1 Trip queued for DownloadComment in the trip info section. )”. [/FONT]
[FONT=&quot]8-[/FONT][FONT=&quot]Repeat steps 3 to 7 for all other pairings in the month. Once done, select “Next” which brings you to the “Trip review and download section”. There you can edit each pairing as you see fit. (I.E. You can edit the crew section to enter only the information you have been used to importing into the logbook. For example, if you are accustomed to entering respective employee numbers, you can edit an add them here before importing to your Palm or PPC.[/FONT]
[FONT=&quot]9-[/FONT][FONT=&quot]Once done importing trips, follow generic steps as provided in APDL documentation based on your PDA type.
JD
[/FONT]
