arrow key to select N-number
gonzo
using the keyboard you can use the down arrow key to pull the dropdown box of different aircraft, and also for routes in the route history.
i am unable to use the down arrow to select from the N-number history. how do i fix this or can this be added to the wish list?
thanks.
You should be able to press F4 to drop a drop down list, then arrow up/dn to select an item.
works great. actually, once you use F4 on the Aircraft Ident window once, you can just use the down arrow key for the rest of the time you're entering data (as long as the program is running). once you close the program and open it again to enter data, you have to hit F4 at the Aircraft Ident window again to make the down arrow work.
however, for the date and aircraft type, you never need to use F4. when you're at that window, just pressing the down arrow cycles you through the available options.
