Automatically includes 1 ILS
PhantomPilot
Using the latest version of Logbook Pro Palm Companion on a Treo 700p. When I added a new logbook entry, under approaches, it defaults to 1 ILS (all other approach categories remain blank). This is a royal pain becuase after every VFR flight, I have to selct 0 ILS's under approaches and often forget and have to edit the logbook. Can this be fixed?
If you don't fly an approach don't view the approach tab and the issue should be resolved. It shouldn't default to 1, however, it may be setting the field active which could trigger a 1 to get entered, or if you tap the ILS field "one-tap auto-entry" will enter a 1, which can be turned off in the preferences.
