Can’t add A320 to aircraft type
coopervane
Anytime I try and add A320 to my AC type it says “you already have an aircraft type 320” the save button is grayed out.
I do not. I have a A321 but no 320. It is not listed.
It is causing all the tail numbers to be assigned to the 321 and this is not correct.
Did you archive the default 320 at some point in the past? You can go to settings > General and enable “show archived data” to display it again, then you can unarchive it and change that “show archived data” setting back
If Andy's suggestion didn't work. Please email at the helpdesk helpdesk @ nc-software.com
