Configure the PDA Logbook
André
Hi there!
Is there any chance to configure the PocketPc Logbook? For example, I don´t need the Take Off and Landing time. I only need Block ON OFF time.
And do I only have to synchronize with Active Sync? ´cause, to via PDA Companion-> Pocket Pc Companion -> Import Pocket Pc Data is always dim!
Best regards
André
Andre,
You cannot configure the display (i.e. hide columns/fields) like in the PC.
As for the Import Queue not being active, ensure you entered your Pocket PC license code in the PC system under the PDA Companions\Pocket PC Companion menu area. The PC version must also be licensed. Therefore when the PC software has both keys/unlock codes entered, the PPC and PC can sync via ActiveSync.
