Resolved Duty period end changing to FDP END?
pcohen
After I input the in time on the last leg the duty end correctly changes to :15 later. Then I do something else, like put in instrument time or an approach and the next time I look at it the duty end and the FDP end have changed to the same time. That has to be a bug, right? Now I have to hit the duty period and hit "adjust times." This is happening a lot. Why is it changing the duty end time?
You are correct. I can duplicate this issue on my end as well. I'll get this reported to be fixed. For now, to prevent this, you can enter all data associated with the flight prior to saving. This only appears to happen when data is edited after it is closed out as you described.
Good catch, thanks for the report!
