I switched from Palm to PC and can't sync with LB pro
Neubyfly
I sync'd fine with palm but now I can't get APDL to sync with LB pro.
The sync software seems to work. It generates a report that is correct but the info is not showing up in my logbook.
Any ideas?
What versions are you using? (APDL, Logbook Pro, SingleSync)
Is your Pocket PC registered? (Options...Enter Key Code)
Did you refresh the data area in Logbook Pro if it was open during the sync?
Did you run through SingleSync and check all the configuration settings since you changed devices?
You may want to consider using our latest release candidate (in the Logbook Pro 1.10 BETA Forum) as it has a new PDA Wizard that replaces SingleSync and is more powerful and reliable than SingleSync, which we are phasing out with the 1.10 release.
LB Pro 1.9.9, ADPL 6.0.2, singlesync 6.1.3
Yes
Yes
Yes
