Is older version available?
gonzo
I need to get ahold of an older version of Schedule Importer. In the new version, nothing gets imported for Aloha Airlines trips. Is there a place where older versions are available?
I'm sorry but we do not maintain older versions, only the latest release is available. Please submit a support ticket and include your trip data and we'll investigate the cause of the issue.
Thank you.
i have submitted a ticket. i was just hoping to find an older version to use until this problem can be fixed since this bug makes the importer function completely useless and i dont know how long it will be for the fix.
thanks.
Our next update is slated for the end of June. I'm sure Josh can address your issue via the help desk system if you require further assistance. We'll discuss potentially an earlier release depending on other issues that may need addressing in this update as well.
Thank you for your continued patience.
The trip copy we have was submitted by someone in your company. I do not know why it is different. I will adjust the filter to support both header formats. I have already given you the look of what the first line should be. Just add in that extra information and it will import fine. We will have this resolved in our next release.
actually it doesnt import fine just by changing the header. all that does is allow the pairing number to be imported. all the trip details are still not imported, even with this "work around".
i was at least one of the ones that submitted multiple trip copies a while back to resolve the slight differences between the pairings for the importer. after that it worked fine.
i've even tried to import trips off of a document from several months ago that i successfully imported in the past with the previous version of Schedule Importer. this seems to suggest that something is wrong with the new version of the importer, not the pairings.
i can submit current trip copies along with copies from last month to a year ago (when it was working) so you can see that nothing has changed with the pairings.
It would be great if you could submit as many trip samples as you can in a new help desk ticket. I suggest just copying them into Word (or Notepad, or PDF) then uploading the single Word doc with your submission. We'll do a full review on this filter and make sure it is resolved on the next update.
Aloha
Filter Input Format:
Sample 1:
A542 AM 8LG HIAM (Base:HNL73202)
Credit: 05:42(Block Time) Check-In:04:45(L) Off Duty:13:47(L) TAFB:09:02 Rest:12:00
Mo Tu We Th Fr Sa Su
01 02 03 04 05 06 --
08 09 10 11 12 13 --
15 16 17 18 19 20 --
22 23 24 25 26 27 --
29 30 01
Flt Cred Duty Blk Flt Day A/C Dep Local Arr Local DH
00:49 HNL 05:30 ITO 06:19 1 40 732
00:47 ITO 06:43 HNL 07:30 1 41 732
00:35 HNL 07:55 OGG 08:30 1 62 732
00:32 OGG 08:58 HNL 09:30 1 63 732
00:35 HNL 09:55 LIH 10:30 1 63 732
00:29 LIH 10:55 HNL 11:24 1 110 732
00:35 HNL 12:00 OGG 12:35 1 110 732
00:32 OGG 13:00 HNL 13:32 04:54 09:02 05:42 1 71 732
Sample 2:
A513 AM 8LG HIAM (Base:HNL73202)
Credit: 05:13(Duty Credit) Check-In:06:10(L) Off Duty:14:51(L) TAFB:08:41 Rest:12:00
02 03 04
05 06 07 08 09 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
00:35 HNL 06:55 LIH 07:30 1 201 732
00:28 LIH 07:55 HNL 08:23 1 204 732
00:35 HNL 08:50 OGG 09:25 1 204 732
00:31 OGG 09:54 HNL 10:25 1 203 732
00:35 HNL 11:00 LIH 11:35 1 203 732
00:28 LIH 12:05 HNL 12:33 1 210 732
00:35 HNL 13:05 OGG 13:40 1 210 732
00:31 OGG 14:05 HNL 14:36 04:18 08:41 05:13 1 211 732
Crew: 1 CAP, 1 FO
Sample 3:
HB02 2DAY 2LG OAK (Base:HNL73G02)
Credit: 11:22(Block Time) Check-In:13:19(L) Off Duty:17:14(L) TAFB:27:55 Rest:18:00
-- -- 02 03 04 --
-- -- -- 09 10 11 --
-- -- -- 16 17 18 --
-- -- -- 23 24 25 --
04:59 HNL 14:34 OAK 21:33 1 442 73G
04:59 06:29 05:05 --- COURTYARD EMERYVILLE (510-652-8777) ---> 12:40
05:32 OAK 11:28 KOA 15:00 2 477 73G
00:39 KOA 16:20 HNL 16:59 05:32 08:46 06:17 2 281 D
neal,
thanks. i've done that. i put a couple samples in a word document, and i've also sent you a current pairing pdf schedule as put out by the company in original format.
do you happen to know if there is another comany that uses these NOVA generated pairings? if so, maybe we could use their filter with small changes to the pairing so at least something would import while we wait. i've tried many different experiments to get at least some of the data imported with no luck so far. it wouldnt be so bad if we didnt regularly fly 8 to 10 legs per day. :)
josh,
here is the same pairing from 2 different original documents. the first one is from september, when the importing worked. the 2nd one is from this month, when it doesnt work.
Sample 1:
A553 (Base:HNL73202) AM 8LG HIAM
Credit: 05:53(Block Time) Check-In:04:55(L) Off Duty:14:24(L) TAFB:09:29 Rest:12:00
31 01 02 03 04
26 27 28 29 30
Day DH Flt A/C Dep Local Arr Local Flt Blk Duty Cred
1 82 732 HNL 05:40 KOA 06:20 00:40
1 85 732 KOA 06:45 HNL 07:23 00:38
1 44 732 HNL 07:55 ITO 08:44 00:49
1 45 732 ITO 09:10 HNL 09:56 00:46
1 220 732 HNL 10:30 OGG 11:05 00:35
1 29 732 OGG 11:35 HNL 12:06 00:31
1 212 732 HNL 12:35 OGG 13:10 00:35
1 277 732 OGG 13:38 HNL 14:09 00:31 05:05 09:29 05:53
Sample 2:
Credit: 05:52(Duty Credit) Check-In:04:30(L) Off Duty:14:17(L) TAFB:09:47 Rest:12:00
-- 02 03 --
05 -- 07 -- -- -- --
Day Flt A/C Dep Local Arr Local Flt Blk Duty Cred
1 23 732 HNL 05:15 LIH 05:50 00:35
1 24 732 LIH 06:20 HNL 06:49 00:29
1 204 732 HNL 08:25 OGG 09:00 00:35
1 203 732 OGG 09:25 HNL 09:57 00:32
1 220 732 HNL 10:25 OGG 11:00 00:35
1 29 732 OGG 11:25 HNL 11:57 00:32
1 212 732 HNL 12:25 OGG 13:00 00:35
1 277 732 OGG 13:30 HNL 14:02 00:32 04:25 09:47 05:52
ok.. i found out whats going on. for some reason it depends on which version of adobe acrobat i am cut and pasting from. when i use adobe acrobat 6.0 professional, it imports just fine. when i use adobe acrobat reader 7.0, it starts to have problems.
i noticed that it changes the way the data is arranged on the clipboard, even tho the layout is exactly the same in the document. i've also noticed that 7.0 is copying extra data that wasnt previously copied (like the "Day" column). that same data is highlighted in 6.0, but for some reason doesnt make it on the clipboard. here's the sample:
Acrobat 6.0 Pro:
F622 DYFR 6LG HIGH (Base:HNL73202)
Credit: 06:22(Duty Credit) Check-In:05:15(L) Off Duty:15:52(L) TAFB:10:37 Rest:12:00
-- 02 -- --
-- -- -- -- 09 -- --
-- -- -- -- 16 -- --
-- -- -- -- 23 -- --
-- -- -- -- 30 --
00:35 HNL 06:00 OGG 06:35 1 924 732
00:31 OGG 07:00 HNL 07:31 1 925 732
00:10 HNL 10:25 HNL 10:35 1 T850
00:35 HNL 11:05 OGG 11:40 1 850 732
00:33 OGG 12:00 ITO 12:33 1 850 732
00:35 ITO 13:35 OGG 14:10 1 851 732
00:32 OGG 14:30 HNL 15:02 1 851 732
00:10 HNL 15:27 HNL 15:37 03:21 10:37 06:22 1 T851
Acrobat Reader 7.0:
F622 (Base:HNL73202) DYFR 6LG HIGH
-- 02 -- --
-- -- -- -- 30 --
1 924 732 HNL 06:00 OGG 06:35 00:35
1 925 732 OGG 07:00 HNL 07:31 00:31
1 T850 HNL 10:25 HNL 10:35 00:10
1 850 732 HNL 11:05 OGG 11:40 00:35
1 850 732 OGG 12:00 ITO 12:33 00:33
1 851 732 ITO 13:35 OGG 14:10 00:35
1 851 732 OGG 14:30 HNL 15:02 00:32
1 T851 HNL 15:27 HNL 15:37 00:10 03:21 10:37 06:22
josh,
thanks. i dont know why adobe has such a wacky copy and paste. i hope this isnt affecting anyone elses importing. at least we know what it is now.
