I have a Dell Axim with PocketPC Ver 4.20.1081 (Build 13100). Active Sync Ver 3.7 (Build 3083). I
downloaded and installed AppForge Booster 3.5.0 (0633). I followed the installation instruction and
cannot access my data. When I tap on the program it starts, shows the startup screen and closes.
I have 2 files on tha Axim: logbook.cdb and lbpro.cdb. I noticed during the installation that I do not
have the same tabler screenas the help file displays (See Below),my table checkboxes
started with tbl****** (ex: tblAircraft), not PDAAircraft. I attached table conversion log below.
\Program Files\Logbook Pro\Logbook.CDB
Figure 4. <!--kadov_tag{{<spaces>}}--><!--kadov_tag{{}}-->Set Database Path, Select Tables for Importing
Monday, October 27, 2003 7:10:00 PM, User: Craig Bennett, synchronization started.
Database: NCSoftware
option: 1 - Overwrite existing tables
option: 1 - Keep this database synchronized
Monday, October 27, 2003 7:11:05 PM, Database transfer begun.
Copying table tblAircraft
Column 's_GUID' is a data type that is not supported. This column will not be copied to device.
Processing indexes:
Index processing has been stopped. There are no more indexes available.
One or more indexes could not be created.
Computing checksums for table tblAircraft.
SQL: SELECT `AircraftID`,`Aircraft`,`Category`,`Class`,`RatingCategory`,`CharacteristicsPower`,`CharacteristicsType`,`RatingClass`,`TypeRatingReq`,`Description`,`Complex`,`HighPerformance`,`Over12500`,`Retractable`,`Simulator`,`Tailwheel`,`CostPerHour`,`TimeEntered`,`Correction` FROM `tblAircraft`
Copying of 43 record(s) completed.
Copying table tblCertificates
Processing indexes:
Indexes over column 's_GUID' are not supported on the device and will not be created.
2 index(es) were successfully created.
Computing checksums for table tblCertificates.
SQL: SELECT `CertificateID`,`Grade`,`Number`,`DateIssue`,`Remarks` FROM `tblCertificates`
Copying of 5 record(s) completed.
Copying table tblCurrAssignments
Processing indexes:
3 index(es) were successfully created.
Computing checksums for table tblCurrAssignments.
SQL: SELECT `AssignmentID`,`Assignment`,`ItemI
![ActiveSync_TableSelects.jpg](http://mk:@MSITStore:C:\Program%20Files\Logbook%20Pro\Logbook.chm::/ActiveSync_TableSelects.jpg)
Processing indexes:
Processing indexes:
Processing indexes:
