Pocket PC tblPalmStats
jtidmore
The tblPalmStats table does not seem to be synchronizing on my iPaq. I have gone back through and checked this table several time in the list of tables to sync. After I do this and try to sync this table becomes unchecked again.
Also, when I choose the tables I want to sync I am getting the following error in the error log:
Tuesday, December 17, 2002 9:53:11 PM, User: default, synchronization started.
Database: NCSoftware
option: 1 - Overwrite existing tables
option: 1 - Keep this database synchronized
Tuesday, December 17, 2002 9:54:05 PM, Database transfer begun.
Copying table PDAAircraft
Processing indexes:
Index processing has been stopped. There are no more indexes available.
2 index(es) were successfully created.
Computing checksums for table PDAAircraft.
SQL: SELECT `AircraftID`,`Aircraft`,`Category`,`Class`,`RatingCategory`,`CharacteristicsPower`,`CharacteristicsType`,`RatingClass`,`TypeRatingReq`,`Description`,`Complex`,`HighPerformance`,`Over12500`,`Retractable`,`Simulator`,`Tailwheel`,`CostPerHour`,`TimeEntered`,`Correction` FROM `PDAAircraft`
Copying of 10 record(s) completed.
Copying table PDACertificates
Processing indexes:
3 index(es) were successfully created.
Computing checksums for table PDACertificates.
SQL: SELECT `CertificateID`,`Grade`,`Number`,`DateIssue`,`Remarks` FROM `PDACertificates`
Copying of 0 record(s) completed.
Copying table PDACustom
Processing indexes:
1 index(es) were successfully created.
Computing checksums for table PDACustom.
SQL: SELECT `CustID`,`Custom1`,`Custom2`,`Custom3`,`Custom4`,`Custom5`,`Custom6`,`Custom7`,`Custom8`,`Custom9`,`Custom10`,`Field1`,`Field2`,`Field3`,`Field4`,`Field5`,`Field6`,`Field7`,`Field8`,`Field9`,`Field10`,`Expense1`,`Expense2`,`Expense3`,`Expense4`,`Expense5`,`Expense6`,`Expense7`,`Expense8`,`Expense9`,`Expense10`,`Counter1`,`Counter2`,`Counter3`,`Counter4`,`Counter5`,`Counter6`,`Counter7`,`Counter8`,`Counter9`,`Counter10`,`txtText1`,`txtText2`,`txtText3`,`txtText4`,`txtText5`,`txtText6`,`txtText7`,`txtText8`,`txtText9`,`txtText10` FROM `PDACustom`
Copying of 1 record(s) completed.
Copying table PDADupTimes
Processing indexes:
Computing checksums for table PDADupTimes.
SQL: SELECT `AutoDupID`,`Aircraft`,`SELand`,`SESea`,`MELand`,`Helo`,`Glider`,`Custom1`,`Custom2`,`Custom3`,`Custom4`,`Custom5`,`Custom6`,`Custom7`,`Custom8`,`Custom9`,`Custom10`,`Night`,`Instrument`,`XC`,`Solo`,`PIC`,`SIC`,`Dual`,`Instructor`,`SEFE`,`Autofill`,`Sim`,`Landing`,`Option1`,`Option2`,`Option3`,`Option4`,`Option5`,`Option6`,`Option7`,`Option8`,`Option9`,`Option10`,`counter1`,`counter2`,`counter3`,`counter4`,`counter5`,`counter6`,`counter7`,`counter8`,`counter9`,`counter10` FROM `PDADupTimes`
Copying of 3 record(s) completed.
Copying table PDAEventExpiration
Processing indexes:
Computing checksums for table PDAEventExpiration.
SQL: SELECT `expireitemid`,`event`,`period`,`eom` FROM `PDAEventExpiration`
Copying of 4 record(s) completed.
Copying table PDAHistory
Processing indexes:
Computing checksums for table PDAHistory.
SQL: SELECT `HistoryID`,`Category`,`Date`,`Remarks`,`DateDue`,`DaysTillDue`,`EOM` FROM `PDAHistory`
Copying table PDALogbook
This IS a bug and it HAS been corrected. A new install of 1.8 has been uploaded to correct this. If you downloaded 1.8 prior to 10:00 PM Eastern 17 December, you can correct this issue by redownloading, uninstall 1.8 and reinstall 1.8.
<ul>]
[[*]]Remove the Database from the Pocket Access settings in ActiveSync
[[*]]Uninstall Logbook Pro from the Pocket PC
[[*]]Delete the Logbook Pro folder from the Program Files area of the Pocket PC
[[*]]Redo the Install procedure for the Pocket PC from the new install of Logbook Pro 1.8
[/list=1]
Thank you for reporting this. It was reported yesterday and fixed last night, hence a new upload of Logbook Pro 1.8. This is only required for people using the Pocket PC Companion unless you want to uninstall and reinstall 1.8 to have the latest setup on your system.
Uninstalling will not delete your Logbook Pro (PC) data OR registration information.
Here is the download for the Active Web Setup
download.logbookpro.com/lbprowebsetup.exe[/list]
