New user with iPaQ h2215
Conflict
Ok Ive read all the FAQ's and have re-installed activesync and logbookpro and the PDA version just as directed in the FAQ's.I keep getting the following msg
One or both synchronization partnership has been moved, deleted or is on a drive that is currently unavaiable.
You may need to disconnect your device and check your settings in Activesync options.
The log then say the following
Friday, April 30, 2004 10:22:48 PM, User: Default, synchronization started.
Synchronizing database Russ.
Synchronizing table PDAAircraft.
An error occurred when checking whether the layout of table PDAAircraft has changed. Reset the device before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDACertificates.
Windows CE Services could not find the synchronization information for
PDACertificates.
ActiveSync could not load synchronization information for table PDACertificates. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDACustom.
PDACustom.
ActiveSync could not load synchronization information for table PDACustom. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDADupTimes.
PDADupTimes.
ActiveSync could not load synchronization information for table PDADupTimes. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDAEventExpiration.
PDAEventExpiration.
ActiveSync could not load synchronization information for table PDAEventExpiration. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDAHistory.
PDAHistory.
ActiveSync could not load synchronization information for table PDAHistory. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDALogbook.
PDALogbook.
ActiveSync could not load synchronization information for table PDALogbook. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDARatings.
PDARatings.
ActiveSync could not load synchronization information for table PDARatings. Ensure file and network permissions are correct before trying to synchronize again. If the problem persists, you may want to copy the database down to the device again.
Synchronizing table PDAUserData.
PDAUserData.
This issue is not related to Logbook Pro but specific to your Pocket PC and ActiveSync configuration. Although outside the realm of Logbook Pro support, I suggest removing your PPC from the cradle, delete the existing partnership(s) from the File menu area of ActiveSync, place the PPC on the cradle and create a new partnership.
