Rest not calculating correctly
raysalmon
I imported a trip into APDL and the last day of a 4 day trip is not calculating rest correctly. I was going to post screenshots but will send them to support instead.
Duty period on the 9th shows 31 hours. That means the duty off date is too far forward. Tap that and see if changing the date of duty off back one fixes it. If not, it is probably the date of one of the OOOI times that is preventing it. Check the dates of all the times.
Yep, the duty off time was for August 10th. Changing it back to August 9th fixed it. Problem is, I copied and pasted the trip straight from Flica into the APDL importer and processed it, so it appears to be an importer issue. I submitted an importer ticket with the flica data for your review.
