Short call reserve, split duty assignment, that ends with a deadhead
beaurice172
I have a short call reserve, split duty assignment, that ends with a deadhead. All the totals look correct (TAFB, credit, block), however the flight duty period is showing 2+59, and it should be 4+19. Any ideas, on what I missed?
Here is the actual schedule. Thank you.
DAY DD DH C FLTNO DPS-ARS DEPT ARRV BLKT GRNT TBLK TDHD TCRD TPAY TDUTY LAYOVER
M9B32F 14JUL17 BSE REPT: 1930 REPORT- 14JUL17 LOCAL Times
Fr 14 N RNV MSP-MSP 1930 1940 0000 146
Fr 14 3796 MSP-YUL 2126 0059 0233 YUL 514
-CREW-ON-DUTY- Marriott Montreal Airport (514)636-6700
Sa 15 DH 3700 YUL-MSP 0613 0747 0250 0233 0250 0523 0523 1232
D-END: 0802 --------------------------------------
TOTALS BLOCK 0233 DHD 0250 CREDIT HRS. 0523 T.A.F.B. 1232
I’m actually not sure what the exact legality for this situation would be since it’s split duty, but deadhead at the end of the duty period is not FDP. It is duty only.
Deadhead at the beginning of a duty period, if it is followed by flights you actually fly, IS part of FDP (since it affects your rest prior to actually flying).
If you’re not actually flying after a deadhead, you can legally deadhead forever with no rest, and it’s not FDP, just duty. You only need rest before you can fly another flight yourself.
So because it’s split duty, that makes it a bit more complex, but I suspect that APDL may be correct since it’s not including the deadhead as FDP at all.
Actually, from a strictly legal standpoint, it may not really be split duty at all. Your company may be treating it as a split duty assignment, but as far as I know, it could be operated as a regular duty assignment since rest is not required prior to a deadhead only.
Hi Andy,
Thanks for the reply. You bring up an interesting point, about it being a split duty. My issue is that my P3 reserve period is from 19:30L-23:59L. I showed, at the airport, with intent to fly, at 19:30L MSP. The flight ended at 23:59L MSP time. My FDP should be 4:19, not 2:59. If I make the schedule two different duty periods, it flags illegal rest. What to do, what to do...
Thanks for the help, Andy.
Best regards,
Beau
Oh it does seem like even just that portion isn’t doing the math correctly. We will have to look into that one some more.
As for split duty, it shouldn’t be two separate duty periods. But in the case of deadhead only, perhaps we need to adjust the code to allow for that.
