TrapAv8r
Is there a way to track the same aircraft with different models? For instance, is there a way to group the T-38A, AT-38B, and AT-38C into T-38 time? I have also separated my Cessna 172 time into 172K, 172L, 172M, etc. I basically added each aircraft model as different aircraft and add up the time using the analyzer, but is there a way you can build that into your log? I was thinking of having a dropdown menu when you log your time. For instance, you can select T-38 as the aircraft you flew, then have a choice of which model. Just a thought.
Scott
Scott
