XC-Distance? is it a feature yet?
AirGonzo
I searched a bit, but hits were old posts,
Question: When putting in to/from airports does the distance "fill" in somewhere? (I think like safelog does, pardon the reference)
I see there is an add on but that looks like it might just be to "view" you flight? or am I missing the obvious?
Thanks!!!
Logbook Pro does not use an internal airport database, it simply records the route as you wish. Therefore, distance is not calculated, but you can track it manually if you wish, if you know the distance.
However, take a look at the FlightCentral Route Browser add-in for Logbook Pro which will read your route entry, parse the airport data and do exactly as you wish.
