Adding Airports in the Airport Wizard
adverseyaw
Detroit, Michigan
I am having a problem adding airports in the airport wizard. I click on the airport I want to add to 'My Airports' in the left window list and then, since it is only an ID change I type in the new airport ID in the box on the bottom and get this error when I press 'ADD':
Multi step operation generated errors. Check each status value.
Any ideas?
Kevin
[edit] I fixed the problem. I just removed 2.01 and reinstalled 2.00
Also note that v2.02, you can set the line width to 0 which will display just the place labels.
Jeff Farris
