APDL and Treo
jamgar
I have a treo 700wx and when using apdl I have to use the scroll bars to see the whole page. I noticed a friend had the same program but on a 700p and it fit perfectly on the screen. I didn't know if you can shrink the page or adjust the text size to fit the screen.
Jim G
Hello Jim,
The Palm OS version of the 700 series device has a significantly higher resolution (320x320) than the Windows Mobile edition at only 240x240. There is a utility that has been discussed by others on this forum that allows you to shrink the scrollbars which will help, I can't seem to remember the name of the utility, you can try searching the forums to see if you can find more information.
jamgar
Thanks for the quick reply, after I posted the message I found the post on shrinking the scrollbars.
MTSUpilot376
Atlanta, GA
To save everyone the trouble it is called EasyTweak set the scroll bars to 8 and that should do the trick.
MTSUpilot376
Atlanta, GA
Treo Pro!!!
Hey the Treo Pro will have a 320 x 320 pixel touchscreen to make all of you WM6 lovers happy! I can't wait to get mine.
