Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
APDL 15.5 is now available on the Apple App Store. Click here to read the release announcement. Click here to go to the Apple App Store to install now.
I've been using APDL on a PDA forever and just got this error. APDL2004.exe TypeLoadException
Now the program won't launch. Any idea how to fix it? I did a soft reset and no Joy!!
Has anything changed on the device? Not sure why you would get this, I do not know the cause. Try syncing with your computer/Logbook Pro to make sure your APDL data gets backed up, you may have to remove/reinstall the app.
There's no reason it shouldn't. Did you enter your registration information on the device after reinstalling, if needed? Are you getting any errors? Is Windows seeing the device and refreshing the files on your PC after Logbook Pro syncs it?
It didn't ask to enter any registrarion info, I'm not getting any errors and Windows mobile is seeing the PDA. Luckly I did a sync before all this happened and I decided to enter a fictional flight to see if it would sync and it didn't. The schedule importer still works though.
On your PC try renaming the folders under /My Documents/My Logbook Pro Files/v1/APDL Pocket PC by adding -OLD on the end and then try the sync again from Logbook Pro.
There are folders with 6-8 digit identifiers, my suggest is rename them so they will be recreated by your device and not have a problem with overwrites if you have a sync issue. I want to make sure Logbook Pro is pulling in the latest file set from your device to troubleshoot the sync issue.
Happy to report that all is well. I didn't have to rename any folders..........I restarted my PC and just getting around to importing my last trip and worked perfectly. Thanks Again!
