Autofill Custom Flight Time Field
jdcollier
Is is possible to create another custom flight time tracking field and have it Autofill the takeoff to landing time result? I basically want to track Off and On totals (Block Time) as well as Takeoff to Landing totals (Flight Time). So far I only see that the Autofill is capable of computing the Duration as specifed in the Logbook options window... I would like to create a similar field for tracking the actual flight time.
jdcollier
As you have noted, Logbook Pro will calculate Duration based off of out/in or takeoff/land times. It does not have the provision for calculated fields such that you can calculate between two other fields.
