Bad APDL Imports
EricW
APDL Beta Team
TN
I've been trying to import my November schedule into APDL via both the older APDL Schedule Importer and the online portal and every attempt to do so results in my Palm Centro soft resetting. This hasn't happened for the 8 months that I've owned the phone. Up until now, importing has been flawless.
Any ideas as to what would cause this? If I were to uninstall APDL and start from scratch would that erase my personalized settings and trip history?
HELP!!
Eric
Eric,
Most likely your DATEBOOK on the Palm is full and prior appointments should be purged, it has a very limited allotment for memory. If the problem remains and you can't get the datebook purged you can disable the datebook integration in APDL by going to the Options...Prefs...General.
I purged the datebook and it now works. Thanks for the usual quick response!
