I have purchased the Professional Edition so that someone else can do the data entry of my paper logs on their laptop and then from time to time update the data on my home pc. I have read the FAQ dated 4/1/2003 and still have some questions.
</o
1) The example assumes that the professional Edition is installed and licensed on both machines. To do this do I download, install and unlock with the same code just as I did on my home pc?
2) As described in the FAQ, there are two scenarios for using both computers. Number 1 describes what to do if I will not be using the computers simultaneously to log flights. Since I will be logging flights at the same time on both machines can I assume that Number 2 gives me the directions that I need when it talks about the Synchronize Wizard?
Thanks for your help, -Bretman
</o
