Can you change Jepp print out?
avee8tor
I have tried looking back in the forum for an answer and spent time in LBP trying to solve this. Although I have created a custom Jepp style logbook format there are several columns I don't need ie. basically blank after I have modified it to my needs. I can't find a way to clear these unused blank columns. If I could I could probably get everything ontoone legal size sheet of paper.
At present I print the standard logbook onto A4 size but without some of the info I would really like by using the custom Jepp style. Any suggestions?
Mark
Hi Mark,
Columns cannot be resized or moved, you can only change the content of a column. What some people do is use the option to generate a report without the cover page, without the gap, then export to PDF and use Adobe Acrobat's advance page 'fitting' to print to a single page, but IIRC they are using 8 1/2 x 14 paper.
HTH
